any guy can tell me how to unlock country code in my n70
imei-357927002060310
how to unlock n70
Only Network Provider can unlock the phone. And read the forun rules!
im from philippines my n70 is lock in smart please help me unlock my phone i want to change my sim to globe
Only network provider🙄
karamvir_rattan wrote:any guy can tell me how to unlock country code in my n70
did u get the codes then i need it to do u have the codes please email me
can the files in Z: b unlocked
Files in Z: are not "locked", but they're first of all read-only as the Z-drive is ROM (non-writable Read-Only Memory). That cannot be changed.
In addition, on devices based on Symbian 9, they're protected from reading by unprivileged apps (processes without the "AllFiles" capability in Symbian terms).
Hi, You can unlock a Nokia N70 safer and easier using unlock code. You can get the unlock code for a Nokia N70 from www.onlinegsmunlock.com/nokia-n70/rs7wp9/ at affordable cost.
Here are the steps for unlocking a Nokia N70,
1 - Switch on your Nokia N70 without any sim card.
2 - Don't bother as to what is displayed on your Nokia N70.
3 - Compose #pw+CODE+1#.
4 - The Nokia N70 would then display the message "SIM Restriction Off" and will be unlocked!
