Some theme editor, pls....
5 replies · 1,866 views · Started 28 September 2006
Hi, there...
I'm a newbie here, and I have a problem with my Nokia 6680.
Once I had a picture in the memory card and I made it as a wallpaper in one of the themes. But I accidentally erased that pic and I didn't back it up on my PC. :frown:
It's so lucky that the wallpaper is still the pic that I erased from the memory card. I think that the pic is in phone memory because it's being used by the theme as the wallpaper, but I can't find that pic anywhere by exploring the phone by using FE-explorer or File Manager. :con?
I wish there's any one of you, who could help me to get that pic again in my wallpaper and back it up to my PC, because that pic means a lot to me.
Thx....
The picture is on C:\Sysytem\Data\backgroundimage.mbm but it is shrinked at your screen size, 176x144. The pictures saved as backgrounds can be found on C:\System\Skins... and they are called Wallpaper.mbm
ratza wrote:The picture is on C:\Sysytem\Data\backgroundimage.mbm but it is shrinked at your screen size, 176x144. The pictures saved as backgrounds can be found on C:\System\Skins... and they are called Wallpaper.mbm
That's so cool, Ratza...
I've found that file you called "backgroundimage.mbm", but how can I convert it into a jpg-file? And also I can't find the file on "C:\System\Skins". There's only a file on that folder named "C:\System\SKINS\101f849\101f849.ini".
Wiz U could help me more on this, please....
You can convert it straight on your phone. The pic is 176x144, right? Your display is 176x208, so the hight is different. Well, get in FExplorer, turn on the screenshot, display the image (full screen or not, it doesn't matter, but don't use the zoom) and capture the screen. You also can capture the screen in standby, but watch out for those extra icons (alarm, headset etc), I don't think you want them in the pic😉 Send the picture to your PC and cut the white borders with the obsolete Paint. Example in the pictures attached.
Attachments: Result.jpg FEscr(001).jpg
:icon14: Bravo Ratza, You are awesome... :icon14: :icon14:
now I've got the pic that I really want so bad back...
