nokia 6680 related question
5 replies · 2,109 views · Started 28 September 2006
I was wondering is there any way how i cand find out to witch provider is locked my 6680 ?
I am not sure about this, but I think that the 6680 works without a SIM (flight mode) and there should be something in the menu.
ratza wrote:I am not sure about this, but I think that the 6680 works without a SIM (flight mode) and there should be something in the menu.
Yes it does work but nothing in the menu nor customization. And about trying what sim work is a litle bit dificult because i`m from romania and the fone is from italy or spain or god knows 😉
i was wodering if there is any soft or code or trick ....
I may be wrong, but I think that the 6680 is a difficult phone to unlock, and can only be done by the network that locked it in the first place. You may not be able to unlock it yourself.
Have you looked through the messages settings or the WAP settings? These might give you a clue as to who the network is , that the last owner used, and therefore who loacked the phone? THe MMS message settings for example might tell you the server ( eg O2, Vodafone ) as well as the GPRS settings? Worth a try.
unfortunetly the phone was formated befor i got it. but thx. anyway. i know i can`t unlock my self that`s why i wanna find out in what network is locked to contact them for the unlock code.
