Yo Guys, i found this site, and this program its supposed to enable A2DP Profile on a S60 v3 phone and it is supposed to work on a 3250, i havent tested it, because i dont have any A2DP Headset, i hope someone can test it on a N80 and give us a feedback.
Here is the Link
Cheers 😃
Dx
according to the site,
*This utility is only available for MSI Bluetooth stereo headset product
so unless u have a MSI headset, otherwise it will be deemed useless.
thanks for the info though. Cheers!
Nokia is going to release a feature set for the symbian 9.1 operating system later in the year that supports A2DP as part of the bluetooth stack. Hopefully this will be included in the next N80 firmware update. Sooo if you want A2DP on your N80 you'll have to wait and pray that this is something that Nokia has in mind. Until then no A2DP.......
Dave
it works fine with N93 the sound is awesome ,but i havn't tried it on N80 yet ,ill try it on N80 and post back
lovher what head set did u use? thanx
lovher wrote:it works fine with N93 the sound is awesome ,but i havn't tried it on N80 yet ,ill try it on N80 and post back
I really hope it works, since i wanna buy a A2DP headset. Let us know if it worked
cheers 😃
Dx
i installed the msi blueplayer ver. 1.4.0814 for nokia 73 and the clip r35 itech bluetooth stereo clip headset, and it works fine but only for just 5-10 secs and then i get a message that this program is only for stereo headset and it stops.
using the n73 media player does not give the same sound quality at all.
please help!!!
hi all, newb here...
got my new n80, trying to get stereo on bluetooth...
any news on a2dp for n80?
