Your help on making a new folder on n80
6 replies · 3,105 views · Started 30 September 2006
please can some one tell me how i can make a new folder on my nokia n80
i want the folder to be in "my own" folder
so from menu to my own, and inside "my own" there i want to make a new folder, i have read the book but nothing there
any idea's, all help welcome
thank you in an advance
I haven't tried this but couldn't you just open up file manager with the phone connected and use windows explorer to create a folder?
I don�t know if I undestand what is the problem. But With FExplorer from windows, or with a similar program for phone can handle that, or not!
Officially you cannot create folders within folders. However I follwed these instructions by Marty3's on SF and managed to create sub-folders on my old 6680. Haven't tried on my N80 tho.
h**p://www.symbian-freak.com/forum/viewtopic.php?t=3944
ok on my n80 i want to do this............
i go in to menu, i see a folder called" MY OWN", on the same screen is folders like web, calender,clock.
i then click on the folder "MY OWN" i see icons like, log, card deck, snakes,go to.
on that screen i want to create a new folder, so i can put new things into it.
that simple to say, but how is it done..........do i need some special software
please help
thank you
6six6 wrote:ok on my n80 i want to do this............
please help
thank you
I'm afraid it's not possible to achieve what you want. You can create new folders in the root menu but you cannot create sub folders within other sub folders. If you click 'Options' when in the root menu you will see the option, 'New folder'. However no such option exists when you enter a sub folder such as 'My Own'.
There maybe 3rd party software that gives you this functionality but I'm afraid I don't know of any.
S.
As I've already said you cannot create folders within folders normally. However if you follow these instructions on SF then you'll be able to trick the menu into letting you create a folder within the My Own folder
