Can any body tale me how to remove the beep tone before phone ring or message tone.
Remove the beep tone
Turn Silent Profile On.
nj7 wrote:Turn Silent Profile On.
But that will also turn off my ring tone. I want to remove beep tone before phone ring. I want my phone ringing without beep tone.
nightbird_bd wrote:But that will also turn off my ring tone. I want to remove beep tone before phone ring. I want my phone ringing without beep tone.
[FONT="Comic Sans MS"][/FONT]Try using mp3cutter or Wavepad. Cut your mp3 and den save as wav. I hope it helps u!!!😊 I suggest u try using Wavepad first. If you need anymore help u can always contact me via msn messenger at [email][email protected][/email]
The other way, is edit the profile You want, and turn off "Other sounds"... (I�m not sure wich is the word that appears in english for that).
that "beep" you are referring to is a security feature by nokia, basically the phone wants to tell you "pull me away from your ear, i'm going to ring!"
yes I know ... it's hardly a "feature"... also considering the shitty loudspeaker...
you can get rid of that beep however by updating the firmware AFAIK
