Background: I've been using the 6800, 6820 & 6822 for some time now.
Edit: Items with an asterisk are solved but rather than delete them I will leave them in case anyone else is searching these issues.
1) I want to mute the welcome tone that's the Nokia tune from the factory.
2) More than half the time when there's an open WiFi system it errors out when trying to connect for reasons unknown to myself.
3) I accidentally press the recorder button (PTT on Euro phones?) on the side of the phone at the inappropriate times WAY too often and would like to disable it entirely. I would like to make it work for something that I actually use but would settle for simply disabling the button if possible to avoid a few issues that I've had already as a result of it.
*4) Voice commands: Doesn't appear to be a way to actually setup a short cut button so you press and hold a single button and then speak the command. I wasn't able to find one in the shortcuts menu nor a way to actually get the phone to a point that allows you to give a command.
*5) The phone will only store ten sent text messages and what seems like an infinite amount of inbox messages. I refer back to my sent messages far too often and would like to be able to save more of them. My 6822 would save considerably more messages and I'm currently using a phone with about 100x the storage space.
6) How do I disable the search all function in the phone book? I had my phone book set up so that I could type the first few letters and now for some reason (actually, I think it started with the new update) it will search the entire entries and list them. An example would be that I have several contacts with the name of Mark and so I list them last name first so upon keying in the first couple letters of their name it would take me right to that entry. I then had another contact by the name of Marlena so before I would type 'M, A, R' and Marlena would be up whereas now I have about ten Marks first and have to scroll down to it. This might be a great feature for some but for me it's just one more inconvenience. I send several thousand SMS per month so little things like this multiply over the coarse of a month.
*7) I don't see any way to display if a particular contact is saved to the phone memory or the SIM card with this phone. I wanted to make sure all my contacts were backed up to the memory card in case something happened to the phone but don't see how. I guess I assume that they are all backed up but it seems fairly simple to allow the phone to display this as you browse the phone book as older Nokia phones do.
8) The USB cable that came w/the phone is absolutely horrible and will not maintain connection. I've finally resorted to criss-crossing a rubber band over the top of the phone and back to the bottom to hold the cable in tight to the phone to keep reception. Otherwise as soon as you select the option to connect and move the phone slightly it loses connection.
9) Is there any way to use an animated gif as your wallpaper? When I select one now to use it never loads the animation and just treats the beginning as a still image. Is there some sort of 'active' wallpaper option or ??
*10) There is no auto key guard feature. All the other Nokia phones I have used going back quite some time have allowed for this and some of the newer ones even allowed to specify a time for activation should the user forget. I'm in a pretty good habit of locking them manually but there are rare instances where I forget and would prefer the phone do it for my after several minutes (user specified the time would be even better) to save accidentally storing/erasing info or calling people inadvertently. The only thing I found was a timed SIM lock that required the PIN every time you wanted to unlock the phone. That's WAY too much effort since I'm locking and unlocking my phone so frequently.
11)That's probably a good start for now. I may add more later but these are the ones off the top of my head right now.
Thanks for reading and feel free to add any input about any of the above even if it's something small as anything is a help at this point. Thanks!
