Hello -- I'm a new member, registering after a while lurking becuase I now have a major problem with my 3230.
This morning I had a panic over some a system error -1 when doing anything in Messaging. So after finding nothing on the net about this, I decided to do a soft format.
I read that your phone should be plugged in for it, so I did. But in my idiot panic, I just read over the battery requirements to do a soft format. I think I was around maybe half or even a third battery power.
So my phone was plugged into the charger, and I did the soft format. About a half-hour later, I was still stuck on a white screen with the Nokia logo. I had to leave the house, so my aphone is still on the charger, hopefully working its way through the reset.
Is there anything I can do? What happens if I did indeed screw up the soft format by not having adequate battery power? It's a software thing, so am I still able to go to a Nokia center and have it fixed?
Any help would be greatly appreciated.
Thanks.
