Wallet Software for E61??
3 replies · 3,761 views · Started 02 October 2006
Anyone has any suggestion for this type of application?
I've tried HandySafe, it's ok but i accidentally press new database and reset the whole thing and i have no backup (-.-) i don't know how to back up the data file actually.
Not used to of how the way the app works, anyone knows any software similar to pocketpc developerone codewallet or maybe flexwallet?
I think there are 3 or 4 applications but I haven't seen a "S60 wallet" face-off yet (hint, hint Steve). On my 9300 I used Outliner which was okay.
So far I think there are:
HandySafe (Expensive)
Wallet Manager for Symbian
BestSafe
Password manager for Symbian
Can you edit the password database/file on both the desktop and phone with any of these applications. I don't think you can with keepass.
From my perspective an application is useless if you can't open and edit it on both the phone and desktop.
You need to be able to edit it on the phone if your at work, for example, and have to change one of your logon passwords.
It's nice to be able to edit it on your home/work desktop computer in case you lose your phone.
Just my 2 cents.
