.....use the flash on n80 as a torch???
thanks
thanks
slammin wrote:.....use the flash on n80 as a torch???thanks
S60SpotOn search google
also first search these forums if you have a question first because your problem has probably been discussed already..I know your question has been asked and discussed several times here before and all answers you will find there...it will save you time
that spot on program wont light up the back flash for some reason, any suggestions? running latest fw.
SpotOn works ok on my n80, but its about as bright as a damp candle, you have to just use the screen light. 😞
khedara wrote:S60SpotOn search google
Pheonix SZ wrote:I think SpotOn's developers need to rewrite it PROPERLY.
i suspect that you cant leave the led on full brightness, if that if you did it will damage it. its normal (and a correct practice) to put two much currant through an led to make it brighter as long as its only on for a short time. i suspect this has been done on the n80,
sm1thson wrote:i suspect that you cant leave the led on full brightness, if that if you did it will damage it. its normal (and a correct practice) to put two much currant through an led to make it brighter as long as its only on for a short time. i suspect this has been done on the n80,
