BL 6C on N80
8 replies · 2,640 views · Started 03 October 2006
waspin wrote:Is it really possible to put a BL 6C battery on the N80?? Anyone have tried?
Given that Nokia say it's compatible only with the E70 and the N-Gage QD, sounds like a really quick way to brick the N80..
But the 5B and 6C have the same voltage (3.7V). I heard a few people were using the 6C on their phones... I just want to be sure that it fit ok
The capacity of the 6C is more than 20% higher than the 5B. I think it's worth a try...
TazUk wrote:Given that Nokia say it's compatible only with the E70 and the N-Gage QD, sounds like a really quick way to brick the N80..
waspin wrote:But the 5B and 6C have the same voltage (3.7V). I heard a few people were using the 6C on their phones... I just want to be sure that it fit ok
Well good luck with that and let us know how you get on.
I bought my N80 sim free and haven't had the same issues with battery life that others have (I don't know why not but I ain't complaining 😊 ).
Given the risk of damaging a 500GBP phone by ignoring manufacturer's advice I personally don't think it's worth it - I would have thought Nokia would have been happy to recommend a more powerful battery that's sold separately if it was truly compatible just to stop the criticisms about battery life..
I would be interested too, BL-5B in n80, was like fitting a 1.0 litre engine in a Dodge Charger, anything to improve it would be most welcome.
err.. has anyone seen the size of a bL-6c????
Its much bigger and there is no way that it will fit in an n80, i would know, I have one here.
What it does fit in and work GREAT is 6600, 6630, 6680, etc etc.
thanks
