HI all
I downloaded the BTPointToPoint on my 7650. Now, I have a CASIRA Bt device and I am using a Bluetooth Protokol Stack called Mezoe BlueStack which is basically the Software that provides the Drivers for differennt Protokols of the CASIRA Bt. Now, when I am choosing Start Reciever from the 7650 and then using the CASIRA As a client, both BT devices connect easily.
But, if I am setting the CASIRA as a Server and set Serial Port profile on the CASIRA and then press CONNECT from the 7650, I get Errors. It says
"App. closed BTPOINTTOPOINT ServiceSearcher 2"
Then the app closes. What is the REason? Can the reason be that the CASIRA is not set sadvertising the BT Serial Port profile properly so that the 7650 can connect to it using the BT Serial POrt profile?
HELP PLease..........
