why my p990 battery is goin flat so soon
5 replies · 4,684 views · Started 03 October 2006
That does rather depend on how long your calls are?
However -- you should have left your phone on charge for about 8 hours or so before the first use. Presumably you (like everyone else) didn't.
You could try lettting it run flat then charge with the phone off for a good 8 hours or so before switching it on. You may need to do this a couple of times to prime the battery.
Also worth turning off any function you do not use -- WLAN, Bluetooth etc.
And the SE phones boost the antenna power if they get a bad signal, so you would suffer if you hang out in bad reception areas.
Or you could just have a duff battery.
It has been noted elsewere on this site that the battery in the P990 gets used up quite quickly, but we are talking a couple of days life, not hours.
I have an idea for you Steed, though I could be wrong...
If you use an exchange server to push your emails, the phone has to maintain contact with it's data stream - effectively staying on all the time. If I'm right and you use the server, it could be draining your battery perhaps...
Good luck with it -
Larry Z.
Most phones have a talk time or around 3 hours... With 20 calls that only 9 minutes each before the battery is flat.
Plus if you use it for other things.
I found it lasts about 2 days ish.
I shouldn't even be reading this forum still, but thought I'd just mention that I had terrible battery life with mine until I switched 3G off. Having done that, the battery lasted ages.
