software for Nokia 3250?
2 replies · 1,381 views · Started 03 October 2006
Most S60 3rd Ed. apps should (and generally do) work just fine on the 3250.
Also, most J2ME Java apps works (those that can handle the Nokia UI API stuff works best, if they've also been written to use the S60 screen resolutions properly).
The "Software" link on the top of the pages on this site should help you find things:
http://www.allaboutsymbian.com/software/Nokia_3250/
