.blz games
3 replies · 4,894 views · Started 03 October 2006
Hello all,
i want to ask if the ngage qd is able to install .blz games or it needs the blz installer program and there are some ngage games that can be downloaded such as pathway to glory .Can I install and play these on the ngage memory card.
Thanks for help.
yanalalhasan wrote:Hello all,
Thanks for help.
I dun think realli can...
of course u can bro....
if for blz files... much easy..coz just put games.blz file (mmc/E root)and then
open blz app(ngage) and click ok. wait after finish reboot yr ngage.
for dos Not blz.files... pls do this matter ok.
Example Call for DUTY/ 6R48
inside folder got Sytem, then open App, data, libs and sharedata.
just follow put in yrs mmc E/sytem/ follow above. easy right.
ps: remember to click PC view HIDDEN ok.
regards.
