E61 Volume
3 replies · 2,188 views · Started 03 October 2006
I just bought Nokia Headset HS-20, AD-41 for my Nokia E61.
Only one problem, the volume is SO low ...is there a way to get higher volume?
Bizarrely, I actually have the opposite problem on my E61, the lowest volume setting is sometimes too loud. 🙄
The first thing you might want to try is plugging the headphone jack into the adapter a bit harder, sometimes the jack doesn't plug in properly and the volume stays too low.
Second thing to try: I'm using a Nokia AD-46 stereo adapter with conventional walkman headphones by Philips and have no problems getting it as loud as I want. Maybe you should try using some other manufacturers' headphones with your adapter instead of Nokia headphones?
Hi Freespin,
The volume is probably so soft because most headsets when turned on, turn down the headset volume of the E61. When connected to the bluetooth headset, make sure that you turn the volume all the way up on the headset. You can see it on the phone if it was turned down.
Wouter
Hmm... I've done everything above.
I've tried my Sony MDR-NX1, well ...better sound - not loud enough though.
Maybe it's the stereo adapter which controls this? Could that be the solution?
I ordered AD-41 because nokia's site said that's the one which fit my phone.
