IRC Applet
17 replies · 96 views · Started 08 December 2002
This thread included a poll: Can you connect IE (or maybe other browsers)
because the other one wasn't free, I went out and found a new free one.
but since some people weren't able to connect we need to know how many of u can't 😊
if you get "to many users in this connection class" or things like this then you are connected but the server is full
[quote="JyriK"]btw the address is:
www.allaboutsymbian.com/chat/applet.php
😃[/quote]
Ty 😉
Works fine in Mozilla 1.1 with the latest Sun JVM (not the sh!te M$ version) installed on windoze, dunno about IE as I don't have it installed for obvious reasons.
The chat.blueyonder.co.uk site is'nt working with me, tried it over and over, i keep getting the same message. Posted it before.
I'm trying out something else. When all fails, you'll find me back here!
I'm back here already 😃
Nothing on IE is working, my vote is has been casted. 😃
[quote="😊"]I'm back here already 😃
Nothing on IE is working, my vote is has been casted. 😃[/quote]
You don't count 😛 you have a firewall 😊
I've got a firewall and a NAT and it still works.....
Maybe we should look at the obvious first point of failing.... IE
I can use it in IE, but I cannot connect 😞 (this seems to be a problem with our network settings at work...) At least MSN Messenger works! 😉
MSN works fine here, but we can't make a big conversation in MSN, only allows a maximum of (what? 5 people?) yeah i guess five. But there is a trick of making more than five work 😃 I did it and it works quite well. But you guys aren't gonna use messenger after all this talk about IRC! So there has to be a way to make it work. For all us poor people that can't make it so 😞
easiest way to check if your firewall allows it:
type in (dos window or shell )
telnet irc.pi.be 6667
if you get response you're firewall is configged as it should and normally mIRC and applet should work.
[quote="Dazler"]easiest way to check if your firewall allows it:
if you get response you're firewall is configged as it should and normally mIRC and applet should work.[/quote]
Hello Dazler,
sorry doesn't work for me 😞 Any other way that I get connected?
