Hi, my question relates to running more than one map simultaneously on Tom Tom 5 on my Nokia 6680. I can quite happily install and run GB maps on its own, or France etc. on their own but is there a way of adding more than one map at the same time? When I install a new map it appears to overwrite a particular file (cannot remember the name) rendering the old map useless.. Apologies is this is a stupid question! Thanks Ash
Running Multiple Maps. TomTom5 on 6680
I've not tried this yet, justusing GB maps on my 6680 ( must say, I'm very impressed with it )
Woud think that perhaps creating a new folder on the root directory and adding the new maps into that? I'm sure you've tried that already, but about all I can think of for now.
TT seems to work if everyting is all loacted in the root directory of the meemory card, so I woudl guess that the main place where the new maps need to be.
Where did you get them from btw - purchased, downloaded, cracked versions?
nottmbantam wrote:I've not tried this yet, justusing GB maps on my 6680 ( must say, I'm very impressed with it )Woud think that perhaps creating a new folder on the root directory and adding the new maps into that? I'm sure you've tried that already, but about all I can think of for now.
Is that way! Just put more maps on root directory. i already have saw a N70 with 4 different maps.
Thanks for your replies, I will try that!
FYI the phone had the software installed when I bought it second hand.
Cheers
Ashc
