help!
16 replies · 1,971 views · Started 04 October 2006
The phone wont read the mem card and its in the right way, it was workin but when i tryed to take a pic while music was playin it said system error or sumthin.Also why cant i put messages that are saved on my pc back into the inbox :{
Format the mem card inside phone.
To move the messages, use the last version of PCSuite - Nokia Phone Browser - Messages.
Menu - Tools - memory - options - format. (may change the words, because I made a tradution from my phone language).
Man, search for a MMC icon in your menu, IT HAS TO BE THERE! It's in every single Symbian phone which has a memory slot. It is called Memory, like nj7 said, like everybody will tell you. Format the phone if you can and search it after.
ratza wrote:Man, search for a MMC icon in your menu, IT HAS TO BE THERE! It's in every single Symbian phone which has a memory slot. It is called Memory, like nj7 said, like everybody will tell you. Format the phone if you can and search it after.
Agree... It must be there!
umm so what am i lookin for? i swear to checked tools, um but the phone wont even read the card so.. yeah think its stuufed
If your sugessin im a kunt that doesent look after his shit then you rong ! :P, na it wont read like i said..yeah its prov damaged inside somehow !
hehe thnx bro will do ! but it shits me cuz iv got an ipod shuffle^^ but i like the loud speaker on the phone , when we play bball its mad :P
,,, are they cheap?
