Serious Problems with Extended Profiles Professional Psiloc
9 replies · 3,264 views · Started 08 December 2002
Hy guys! After a lot of silent reading, here my first post (no Im not shy...)
Till now I got anything running on my 7650. With The eProfiles Professional I have serious Problems. The installation is no problem, also the program seems to run, but:
When I want to personalise, change or do anything with the program nothing happens, the only thing I can change is the automatic key lock.
But it only after I restart the phone once.
I cant change the alarm tone, the calendar tone, the background, the menu colour or anything else.
If this software would work, it would be exactly what i was looking for (changing the tones of alarm and calendar).
Does anybody use it or has some hints how I could get it to run?
Following applications are on my 7650:
Image Plus
Oplaya
Active Desk
TMobile Video
Bemused
Handy File
Forward
Torch
Webviewer
Sheet
Language is set on german, 1,5 MB free on the phone, no other problems.
I dont know which firmware my phone has.
If anyone could help it would be great!
Thanks guys!
:-? aye? weird problem. Did you try uninstalling it then installing it again? Or maybe you have a screwed up file? :-?
Looks like the e profiles you have here is unusable! Nobody ever complained about these (although they did complain about problems with the alarm sound, but i think it worked in the end 😊)
get another version!
One idea is that after you personalise the profile, you should press OK instead of Back. The others applications save settings when pressing Back, but this one is different, I don’t know why :-? , and save settings only when press OK. This was a little bit confusing at the beginning, so I forgot many times to press OK and I was wondering why is not working. But in your case there might be other problems as well...
well it's true, press OK when you're done! i'm also using it and never had problems with it! well to be honest once, when using space doubler version 0.97b, i accidentally pressed a key while it was still compressing and it was gone!! i mean the icon is gone and even with SeleQ it was nowhere to be found!! 😃
well press OK !!!
after setting all the profiles try to activate each one then go back to the one u want
close the mobile and on again
all should be working now
good luck
Wow guys this forum is great (sure Im not the first one who recognices this...)
Didos I think that was the problem, I can now at least change some of the settings. Ill report if I finally got everything working.
Thank you!
OK, now the profiles work, alarm clock works. Thank you!
But I got a new problem! The alarm of the calendar works sometimes and sometimes not. I dont mean the ringing tone, I mean in generally, no alarm at all with the calendar. Usually when I restart the phone it works again.
I am using active desktop for editing alarms and calendar, but it integrates the datas directly into the nokia calendar.
I dont know, but obviously my 7650 doesnt like me anymore....
Anybody can help?
Thanks in advance!
if e-profile and world-clock pro work together,somethimes it seems to be a troubel with the alarm enh.
Try once only e-profiles,it should work ok.
(For multialarm only make a Calendar-entry 😉 )
S�mi
macisback
seems that your 7650 is fullup
and programs interfear together
try *7370*#
to format your 7650 to factory setting and reinstall all programs that you want only
