Theme Problem with M600i
2 replies · 3,999 views · Started 05 October 2006
Hello Everyone
After getting my new M600i, I was on looking for some themes on the Internet- did find some but when I install them they dont appear as they do when I preview them before downloading from the site.
On my Homescreen which is set to Today Screen- it doesnt show the little icons at the bottom and it paints the background color as solid but doesnt display the theme correctly. Is there something I'm doing wrong. I really like some of the themes but can't get anything working except the ones that came with the phone.
Attached a picture.
Attachments: untitled.JPG
Not sure I exactly understand this question but the icons you talk about are not theme icons they are application icons,
messaging
contacts
controlpanel
filemanager
calendar
you can change what applications you see in the homescreen by selecting more->replace (when an icon is highlighted)
mxnmx, I have the same prob..... per chance, your phone isn't Vodafone branded is it??
Vodafone have been really daft with this..... I can't believe they thought this was an improvement!!!!!! Finding Apps becomes a real task when compared to the normal M600's branding..... just annoys me that they can't even give a fix for it..... useless!!
