Bluetooth and winXP problems
7 replies · 2,265 views · Started 06 December 2002
well not for mee
i have a bluetooth receiver from microsoft and there are no "services" for the "phone".
he connects it wel.. asking psw etc.. but nothing further.. no com port or etc..
sorry to hear it dude
but
not being able to pair your phone is sod all to do with the pc suite !
search the board in nokia7650 for bluetooth and i swear you will be connected within half an hour
just for quickness
pair your phone with your pc....the procedure for this is in the manual
i assume you are using the widcomm stack with latest drivers
now, open up mrouter, if you have installed pc suite, it will be in your taskbar. tick all the boxes for com ports.....(default is com4 (well...stack says com0, but it means com4)
double click on your "my bluetooth places" icon. go to "view devices in range". Your phone will appear here. If it doesnt, it is either out of range, BT not switched on in your phone or you havent paired it properly.
right click on your phone and select "connect bluetooth serial port" the brackets will appear round the circle on your top rigt phone display (o) then the PC will tell you that conenction has failed.
look at the mrouter icon, it will now flash with an icon meaning data is being transferred. Then it will go green to show its connected
enjoy
now, you can start up pc suite and it will work fine
here you see an overview, so the connection is verified (with psw etc)
i can't do a right click but i go to properties en and go to services (drivers or bridges normaly i think) nothing is filled here or can be added
this is from my mouse, you see that have a services (driver)
anyone know a solution?
@naivri thx for the help but i am stuck an looked for 5 houres 😞
[quote="YLA"]User posted image
@naivri thx for the help but i am stuck an looked for 5 houres 😞[/quote]
its maybe not on topic anymore but i have still the problems.. solution?
Sorry, this is 7650 news section, so ill move this to right place 😃
Maybe there is someone that can help you.
Have you guys being upgraded your Bluetooth driver? Coz I have same problem with it.. but after i have upgrade the driver, it's work! 😉 Took me few hours to know it!
