Hi guyz i'm planning to buy handphone as my current handphone is old. Can anyone tell me which handphone is better??? NOKIA 3230 or NOKIA 7610???
Pls specify why you think this phone is the best. thx you😉
7610
pluses:
- strength of the signal is better than in 3230
- battery lasts longer
minuses:
- keyboard's layout makes it pretty difficult to use
- no IrDA
- 1 MPx camera 4x zoom
3230
pluses:
- 1.3 MPx camera 6x zoom
- brightest display
- almost all series 60 apps for v1 and v2 are running on it
minuses:
- battery life too short
- weak signal
- restarts often
Of course, there are a lot of things to compare, but this is what I consider to be the most important.
For me: more or less the same, with only one big difference, FM Radio on 3230😎
Wirelessly posted (Nokia3230/2.0 (5.0604.0) SymbianOS/7.0s Series60/2.1 Profile/MIDP-2.0 Configuration/CLDC-1.0)
nj7 wrote:For me: more or less the same, with only one big difference, FM Radio on 3230😎
What about camera quality in 7610
The quality is worse in 7610 than in 3230. I had the 3230 and I wasn't so happy with it.
