Hi everyone,just finished my first skin for the 9210. I made it mainly for myself but if anyone else likes it then all the better.
A big thanks to Dazler for his mbm tutorial,it shaved potential hours off the making of this skin by not making me work out how to use the bmconv tool 😃 ! Also if someone could point me in the direction of an "Editing the display.rsc" file i wold be most appreciative..i had to just substitute letters over the original file rather than name them as i wished!
btw the file is zipped in rar format which i believe is recognised by most zip agents now,if not shout at me and i will post a '.zip' version 😃
I'll check it tonight 😊
BTw I don't have a better way of creating a .rsc file than just replacing the letters in a hex editor 😉
good work man.. keep on posting your new skins 😉
At least I was unable to open the file with my Winzip. So if you can post it again in zip-format, I would appreciate. Thanks
[quote="LAuRA"]At least I was unable to open the file with my Winzip. So if you can post it again in zip-format, I would appreciate. Thanks[/quote]
download WinRAR, as simple as that 8)
http://www.rarlab.com
Good luck 😉
Tsk xXx..as the lady wishes so shall it shall be done 8)
Btw i am afraid some of them are a bit dark which can be difficult to see in alot of light. I suppose i should try and brighten them up a bit, but i tend not to read what the cba buttons say anymore as i know what they are.
By the way any critcisms etc about my skin are welcome 😃
I do not know how to use it :cry:
The same way you would use my skins 😉
the jpg files are to be used in Desk. The display.mbm should replace the old one in c:\system\data\
and display.rsc replaces the one in c:\system\controls
