Even after the update I cant access any of the installed themes in the app manager, i would like to format the memory card and only want to do it through the phone and i suspect themes are to blame. Anyone help or have same problem??
Themes not displayed in App manager - cant unistall.
Try install again and after that see if is possible the remotion.
Delete them from Themes submenu. It will work like that.
Thanks. When you mean submenu do u mean in tools>themes, i press the c button for deleting but nothing happens.
Exactly: Tools->Themes, highlight the theme you want to delete and press "c" button. If the theme is a default one, you can't delete it because is in ROM and it doesn't waste any memory of the phone/MMC.
NNOnothing is happening when i press C!
OK, sorted now. Select different wallpapers for all your themes and remember them. Go to C or E:\System\Skins and search in those directories for the wallpaper of the theme you want to delete. When you find it, go back and delete the directory.
