SmartMovie replacer
9 replies · 8,258 views · Started 06 October 2006
Is that any good from smart movie? Think still the best out there in terms in quality video and audio whats more it also include a convertor which makes it a breeze to use.
maybe we can use the free pocket divx encoder, it is also made to convert for smaller mobile phone screens
I use that app for my Pocket PC
UPDATE
just installed the app, it works good but SmartMovie is better, I used the same files on my MMC that I watch with SmartMovie aswell and the audio quality is a lot worse then SmartMovie.
Also SmartMovie is in a lot of languages and you got the option in the Divxplayer but you can't change it, the only things you can change are the audio and subtitle language.
I use SmartMovie 2.76
It's a nice start, if you have no experience with SmartMovie you'll love it, and ofcourse its free
I am using DivX Player only when I want to see a movie with subtitles, otherwise I am using TCPMP (alot smoother, faster and with more codecs).
On my PDA I use TCPMP aswell but I didn't know there was a symbian version available aswell.
About that divx player, I found how to get rid of the noisy splash screen when you open the app.
In FExplorer go to: System\Apps\DivXPlayer\Splash\ in here you cut the avi file and paste it for explample in the Demos folder or some where else.
So next time you start up DivXplayer it opens directly and silently.
Does somebody already find out how to change the language? I can only choose english
