6630 trouble with g3 internet connection
4 replies · 2,800 views · Started 06 October 2006
i was browsing internet on my 6630 perfectly until i decided to upgrade my internet connection to the 3Generation serive which is faster.the problem is that after i upgrade to this fast internet service, i no more able to browse.old internet connection gives only 150kb and the new one is 460kb.i get that speed. my friend has simialr problem, he can browse perfectly but only with the same old internet speed which is 150kb. he tried to get 460kb but he couldn't.
nj7, do you want to bet?😎
1 byte is 8 bits so after a simple calculation (though I doubt you can do this) we have 384 kilobits / 8 = 48 kilobytes. One byte can be used to have 256 different values. I am doing this every single day at work. And another thing: B means byte, b means bit, if you can distinguish the capitals.
