Installing software problem
1 replies · 1,626 views · Started 06 October 2006
Hi, just got registered to this forum. Need help regarding my Nokia 6600.
I've been using my Nokia 6600 for the past two years. I installed the PC suite/ Modem and all other related software. Everything works fine. Recently I got a used Nokia 3660 and install PC suite software into the same PC. Works ok. My problem is when I tried to install new software into my 6600 (.sis) the PC indicate that its the wrong phone.
My question is: How do I revert it back so i can use the PC suite to install my 6600?:con?
I do want to retain the 3660 PC suite but I want to install new software to my 6600. If I can do both (installing software & Use PC suite would be great). But if not I would rather have it on the 6600.
Any help would be appreciated!
PS I did try to re-install the 6600's PC suite but nothing happened. Still looks for the 3660 phone
They may conflic... The best way, is copy the files to the MMC card of 6600, and install then inside the phone.
