memory problems after first install.
4 replies · 2,244 views · Started 09 December 2002
something I liked to share with you guys.after uploading doom to the 7650,the game had problems working after a few more tries it started working anyway t would not take any pics .after restarting the phone it worked up all fine.has anybody experienced this?
also Since I will be getting my second phones will try to avoid anything that kills the phone(contact retailer screen)
the first thing I have learnt is not to format unless the phone is completely charged and pn the charger.
one other thing I had had heard of is changing fonts,can anybody verify this also anything else I have to avoid?
Finally in which firmware does the nokia cd come with?
Problems with doom eh? did you install it just the way it should be? (by the steps it should be installed?) I used to have Doom and it was working fine, so did the camera, i uninstalled is succefully with no problem!
Yeah you're right about formatting, don't do it until it's fully charged and the charger pin is connected, as if there isn't enough power the phone will not complete it's formatting task! And it will get screwed up and get bugs or whatever.
DON'T TRY TO CHANGE THE FONT!!!! that's a piece of advice from an experienced user (mbuffy) as he tried to changed it and ended up with his phone in the NSC for a long time. Don't try it any way or another!
the nokia cd comes with all firmwares does'nt it? I have version 3.12 and i got the nokia cd with it :-? . Might want to contact the place where you bought it from, maybe they forgot it! (or took it for some reason)
our phones are to much like pc's we have to reboot after installing some software thats manly the problem
Actually Nokia and Symbian promised that Symbian OS phones and devices do not need to be retarted. However that is only true in dreams and in utopian societies.
A huge percentage of the apps i installed I didn't have to restart the phone for them, even some apps ask for the phone to be restarted but i just go on and they work! But rarley i actually do restart ( I hate doing so cause my power button is almost useless!)
