well guys i have a 512 mb memory card and i have installed around 60 - 70 applications on the card <both .sis and .jar apps without any problem> so i just wanted to know if at all any problem arises with the increase no. of installed apps and also is the no. of applications instaaled solely dependent on the free memory space available or otherwise???
MAX no. of applications??? 6600
yup!
probably your fone will operate slow...
Can you tell me if you know what is a .db, .dat, and .ini file??? why are those files on my c.p. has a type of audio instead of unknown and when i try opening it, it says error?
No problem. You can install all You want!
well , can you say something about what this?
is there any one who can help me?
sorry for the bad english>>>>hehehe
.db .ini and .dat are metadata files of installed apps. Ya even in my FExplorer it shows up as sound files, must be a bug of Fexplorer.
Newayz dont delete those files coz they are important for the working of your cell.
NahSoR wrote:.db .ini and .dat are metadata files of installed apps. Ya even in my FExplorer it shows up as sound files, must be a bug of Fexplorer.Newayz dont delete those files coz they are important for the working of your cell.
thanks
