hello, im hoping someone can help cos this is doing my head in,😡
the problem is some times it works and sometimes it doesnt it just stops half way and says connection lost but the phones still connected, im not sure if its the phone or the pc please help
thanks
installing games via bluetooth
Can you tell me if you know what is a .db, .dat, and .ini file??? why are those files on my c.p. has a type of audio instead of unknown and when i try opening it, it says error?
is there any problem with my fone???
It was not like that before....
My bet is PCSuite. Uninstall all, use a regclean program and clean all entries PCSuite related, reboot PC and install again. Do a new pairing process and see if it works. Another thing, to install programs on phones, the best way, is copy then to a folder on card and after with some Explorer program, execute them. IS the fast and reliable way to do.
thanks but i downloaded a newer version of pcsuite but still same problem
viny wrote:thanks but i downloaded a newer version of pcsuite but still same problem
Copy / Paste them to the Card and install inside. After that You have time to test the rest.
brilliant thanks a lot didnt realise you could do that, shame i cant do it over though but thanks again
Bluetooth problems are frequent... and is try and error thing untill the solution. With Copy / Paste You don�t get limited for now.
The PC Suite generally gives problem that is my usual experience and you need to uninstall and reinstall it everytime to get work from it.
Isn't there any fair alternative to this?
With regards,
Mandar Thosar
