bluetooth question
8 replies · 1,663 views · Started 07 October 2006
i have a nokia 6600 is there any software which can run my bluetooth headset and my tomtom gps aswell cheers
burger01 wrote:i have a nokia 6600 is there any software which can run my bluetooth headset and my tomtom gps aswell cheers
Search for an app called BTex. This allows you to have 2 simultaneous connections via BT.
Options -> Start slave and you have two connections. Try to send two files on the same time, on different phones/dongles.
