i tried to run the installed pdf reader with a couple of files i have and i get low memory erros even if i have 44mb of available memory!!
i hear there is bad memory management, is this true?
low memory issues on N73
True, Yes! You have C disk free with 44Mb, but not RAM free... RAM on N73 (and other new N phones) reach critical levels easy. Is like that😡
You might have too many apps running.
Press and hold the Menu Key (left of the 1 & 4) and you will see a list of open apps. You can shut them down one by one to free up ram.
Yes there are DEFINITELY problems - I can't zoom in on most of photos due to not enough memory - Even after a hard reset! 😞
I keep meaning to check if the photo file size has any bearing on it but I would assume so??
