Can anyone tell me how to fix this problem?? The problem is everytime i open my asphalt, it will start nicely until it reaches the "gameloft" screen and it will pop out " Memory Full. Close some applications and try again" but i nvr open any application except asphalt. Anyonne can help????😡 :con? 😮
Thx in advance!😊
*my game is original which i bought from nokia store.
Should not be the program it self... Maybe some conflit with other background running process. Use FExplorer to see if You have something running on background, and close the unwanted ones.
if nj7 still the same......problem
try to replace Asphalt (6r67) and (libs) agian, if ya was download from some place..lol..
if its real original from ngage... better change to new 1.... lol...😊
Sorry... I thought You talk about original one. If is not the case, see the forum rules first!
