Today I've tried to reset the data counters in Log on my E61. And the phone asked me for a "Lock code". In the pure S60 tradition of confusing the user as much as possible, it didn't say what "Lock code" it was after. There must be dozens of lock codes in this phone and they're all called the same.
So i've tried to enter 12345 as it's usually the default "Lock code" in S60. Didn't work. Now, i might have changed the "Lock code" a while ago but the "Lock code" i potentially changed was maybe not the "Lock code" but the "Lock code" or maybe the "Lock code" or even the "Lock code". Who knows, they're all called the same. And maybe they're all the same. I don't know. And i'm pretty sure that even God doesn't know.
So i'd appreciate a bit of help here because i don't like being locked out of my own device. Concerning the "Lock code" in Log:
- is this code the same as other "Lock code"? If yes, which are they?
- where can this "Lock code" be set and changed?
- what is the default value of this lock code?
- is this "Lock code" usually composed of numbers only or is it an alphanumeric code?
- is there a minimum/fixed/maximum length for this code?
thanks a lot for any help. I've tried several code and even looked in the help file to no avail.
