N91
6 replies · 3,801 views · Started 08 October 2006
I have had this phone for awhile, i have had music on there all the time. Suddenly it said there wasn't any songs on my phone. I looked on the phone through my PC and they still showed up there. I deleted them and have tried since to put them back, through drag and drop (still same thing, saying no songs) and through the music manager, when it goes to start transferring over, it says unknown error on the music manager.
Any ideas?
thanks
Hi
What sw version do you have (*#0000# will tell you). I suggest looking at my 15 User advice tips and see if it helps (sounds like teh Music Player database was screwed up somehow)
music
Hi
Please see the 15 User Advice tips I posted (use search) it points you to the sw update info.
music
