Hi
Just needed clarification on something if anyone can help? I going to purchase a N73 and currently have a 6680. I want to transfer all my current MMC memory data to the SD cards that the N73 takes.
Will I need a card reader to do this, and is it possible for me to transfer data from my MMC card to PC (via the card reader) and then back to a SD card?
Help??:
Deep
You need to copy all of your data off the mmc on to your pc first. Using Nokia Pc suite software (available at www.nokia.co.uk). Then using just copy it back. easiest just using copy and paste in the nokia phone browser found in my computer.
Depends of which kind of card reader you possess. Mine has four card slots but it reads 23 different types and you can drag and drop from one card to another if they are both inserted. This spares alot of time.
