Hi all
I dropped my phone on the concrete outside today and have dinged it badly. 😡 Unhappy now and want to change the housing. Anyone know of any guides on how to do it? Is it very difficult? Found some housings on ebay but unsure as to how to proceed with swapping it.
Cheers in advance.
There was a really good guide by some mac user called the reamer, but the link is dead now 😞
maybe someone has a copy of it...
this was the link, http://web.mac.com/the_reamer/iWeb/freestyle/N80%20Strip%20P.html
found this other link which shows how to replace the LCD, so shows how to remove 1st half of the cover...
http://www.formymobile.co.uk/n80lcd.htm
ut.
bertroot wrote:Hi allI dropped my phone on the concrete outside today and have dinged it badly. 😡 Unhappy now and want to change the housing. Anyone know of any guides on how to do it? Is it very difficult? Found some housings on ebay but unsure as to how to proceed with swapping it.
Cheers in advance.
Removing the front cover is dead simple...
With the slider open, there's 2 screws on the back - although you should buy a special tool, Poundstretchers sell Jeweller's screwdriver sets, and one of the flat blade ones works fine with the odd Nokia screws.
Once the 2 screws have been removed, carefully prize the cover away from the case with your fingernail, starting at the bottom of the phone working your way up. The repeat for the other side.
Replacing the front cover is the same but just in reverse sequence.
Unfortunately I don't have any details how to remove the back cover, etc.
Cheers in advance.
Here, dude - I just uploaded this : -
http://rapidshare.de/files/36144789/Disassembly_Nokia_N80.zip.html
Pheonix SZ wrote:Here, dude - I just uploaded this : -http://rapidshare.de/files/36144789/Disassembly_Nokia_N80.zip.html
Comes in at 508kb but winzip claims it is corrupt. Tried off two mirrors. Could you possibly reupload it? Nice one for the file though. 😉
bertroot wrote:Comes in at 508kb but winzip claims it is corrupt. Tried off two mirrors. Could you possibly reupload it? Nice one for the file though. 😉
You don't do much P2P, do you ?
Don't worry about corrupt headers, just unzip it.
It's all there, I've just D/L'd myself.
Theres very cheap housing on ebay that comes with the necessary tools to install it.
