I've got an icon on my phone display just under the battery bar on the right hand side of the screen.
Its two circles joined at the bottom similar to this: O_O
The left circle is coloured black though.
Anyone know what this means? i can't find it in the book.. it doesn't show that icon in the list
thanks 😊
I think it means you've got voicemail.
nope - definitely no voicemails
The phones usually have an User Manual... do You already check this😉
This icon means that you have voicemail on one of the two lines of your SIM. Change the line and listen your voicemail.
yep deffo voicemail, are you on orange?
Taingster wrote:nope - definitely no voicemails
regardless of what you think you have, that's what the icon means.
The o_o icon is set & unset by your network. If that icon is showing on your handset, even after you reboot it, and you definately have no voicemails, then it is your network's fault.
SL
OH i c.. thanks for the replies.
Yes i'm on orange
if you dont have any new messages make sure you dont have any saved ones, it might be a bug causing a saved message to display it?
leave yourself a voicemail, and check it, see if it goes away.
yeah its definately an answerphone message icon, i had the same problem, the icon was ever present even with no message, i corrected the problem eventually by leaving myself a message from a landline, listerning to it, deleting it, but don't exit the answer phone untill the icon disappears :icon14:
