N71 Contacts
5 replies · 4,244 views · Started 10 October 2006
😡 Does anybody knows how I can manage ALL features of Contacts and Groups through my PC? Even I make groups (in Outlook 2000) and attach the contacts on them, there is not any assignment on the phone, groups are not even created. Also when using the "special" folder for Contacts in Windows Explorer, groups are also absent. I did not found also a methode to assign (through PC) "default" phone numbers on voice calls, messages etc. Is there any "comunication protocol" in order to read and write contacts and groups directly from/to phone when connected through USB or IR ? (I can write my own software, in Visual Basic or C++)
nj7 wrote:You can�t. Only if You write your onw SW.
OK I will write it. Do you know where I can find info about comunication protocol commands etc ?
alexkots...........did you get anywhere with this? if so could you advise me, 'cause i want to do more or less the same thing.
I manage my contacts through my PC with Nokia PC Suite/Contacts but for groups I'm not sure
