slide & end call
6 replies · 3,715 views · Started 10 October 2006
Hi there,
Is there an option to end calls by sliding the phone back? I still forget to push end call button :/
Thanks,
Serhat
mine does end the call when i slide it closed! dont know if theres an option to change it.
what firmware (*#0000#) do you have mines 3.0618.0.2 (on three uk)
sm1thson wrote:mine does end the call when i slide it closed! dont know if theres an option to change it.
Hello,
When someone calls me, sliding ends the call. When I call someone, sliding back does not end the call. It happens this way. I call someone, he/she doesn't responds in a few ring, then I slide back the phone to end call. But it keeps ringing other side forever. After a minute or two, he or she answers the phone only to hear strange noises (I'm away from the phone) :/
I've recently upgraded firmware version to V 4.0623.0.41.
on ver 3 it will end the calls but this upset ppl with hands free as theyd have to keep there fone open whilst on a call, so version 4 wont end the call
The slide doesn't end calls if it's connected to a hand-free kit.. I've just tried on my v4 firmware, and closing the slide when not connected always ends the call, unless you press the "options" key first, this will bring up a menu and you can close the slider without ending the call.
mcsleazycrisps wrote:unless you press the "options" key first, this will bring up a menu and you can close the slider without ending the call.
-a very handy tip, thanks!
lordlothar wrote:Hello,
thats totally right, is there anyway to let the sliding end the calls i make ??
