Free up space on hard drive
3 replies · 1,882 views · Started 10 October 2006
My C: drive has only 13% space left on it. What should I do to free up space. Already did disk scan. Won't defrag because needs 15% to defrag properly. Can something be deleted. Moved to another drive?😮
If you're talking about PC hard drive, you're on the wrong forum mate 😉
Anyway, move some data to other disk drive or on a CD.
And if you're talking about your phone: move videos, sounds/music to the memory card, move messages to the memory card, uninstall apps and reinstall them on the memory card.
Goto C: > Data > Installs
I usually delete everything in there because they are just install files which installs the apps. You can always get them and reinstall from your pc.
