change memory card
2 replies · 1,754 views · Started 11 October 2006
I just bought 2gb sandisk card and then copied everything from old card to new one. I can't see any applications which where installed on the memoy card.
Is there any special procedure to transfer data from one memory card to another?
thanks.
You need to copy all the files from the old card because some of them are maked as hidden. Turn on the option for seeing all files in Windows Explorer (Tool->Folder options...->View tab->Show hidden files and folders). After this, copy the card again.
It seems that it is a problem with nokia phone browser and hidden files and you have to use card reader.
Thanks.
