Word and Sheet application question
4 replies · 2,586 views · Started 09 December 2002
is there anyway i can change the default settings of word and sheet application in the communicator? coz everytime i open word it goes back to big fonts and i have to manually make it smaller and in sheet i always have to go through the tedious taks of changing the row height of cells and width and also change to wrap text and font size
if there is a way i need to know badly.. thanks
dude ive tried that already but doesnt seem to work.. everytime i close the program and start it again, it reverts back to the old settings. m using a 9210i
Dazler's trick worked on my 9210. I saved the template and that was it. But I guess you need to change the font both in the document first and then in the template. I juggled a bit between different save-modes and first ended up having pre-set text on my normal template, but eventually I got it right. 😃
