where to put voices in tomtom
4 replies · 2,256 views · Started 12 October 2006
ok i have got some extra voices and poi for tomtom where exactly do i put them (into what folder)
thanks for the help
Funnily enough there's a folder called "VOICES" on your memory card that'll happily accomodate your voice files for TomTom. 😉
As for POI they go in the same folder as your map e.g. Great_Britain
hey all, sorry to be a pain.i really cant figure out were to put the maps? plz help confused noobie loosing hair fast
all help appreciated😃
hashhater wrote:hey all, sorry to be a pain.i really cant figure out were to put the maps? plz help confused noobie loosing hair fast
just drop it onto the mmc as it is, tomtom will find it.
