How to change the content of a list box dynamically?
2 replies · 2,976 views · Started 09 December 2002
I can't find a solution!!! 😮(
I just want to add a new entry into my CAknDoubleNumberStyleListBox...
But all I found out till now is how to create a new entry (and overwrite everything)... But I need to add a new entry after the existing entries...
How can I do that? Didnt find any help in the SDK...
Thank you guys...
Wumms
I don't know a CAknDoubleNumberStyleListBox. The following will work for any listbox that uses the CTextListBoxModel as model.
[code:1]CTextListBoxModel* lbModel = (CTextListBoxModel*)iLbox->Model();
CDesCArray* textarray = (CDesCArray*)lbModel->ItemTextArray();
textarray->InsertL(pos, newtext);
iLbox->HandleItemAdditionL();
iLbox->UpdateScrollBarsL();
iLbox->DrawDeferred();[/code:1]
