I am looking like h#%! for an easy to use To Do list for the 7650. It must include alarm function.
And hopefully for free.....
Am I the only one who can not find one!!!
i think you may have to pay for it i was looking for a way just to change the alarm tone and i had to pay for that gutted or what on my old 3330 i could change the alarm but nooooo not on my 7650 dont get me wrong i love it but sometimes i think that nokia had one over on me
You are right about some of the things you are saying...
Hopefully some product will surface some day. Currently I am using my 9210i for calendar and alarms - I would like to use the 7650 instead!!!
An alarm function and being able to put to-do items in to a catagory and integrate with the standard to-do app would be just what I need.
Hummm ...
That's could be interesting for me .... I'm just looking for ideas to develop new soft and free soft .....
Dominique HUGO
FileExplorer 1.04
[email protected]
Domi if you could create something like this it would be great 😊 I like alarms as i am quite forgetful so usually use the calendars meetings instead of to-dos which makes the calendar ugly and disorganised.
Stezos
just a thought - actually, if you have wolrd clock pro this might to it for you. set you to-do thing in world clock pro as alarm (you can do that in the message prompt). just a thought - that's what i do. 8)
but yes, still cant change alarm tone with world clock pro.
World Alarm might be a solution. But the best would be to have an independent solution. Just like mentioned earlier.
Looking forward to seeing something someday hopefully :cry:
