I'm trying to get my N80 to work with my wireless network.
The N80 connects to the network, but when I try to surf the web i get the error "Web - No gateway reply"
I've tried changing the security settings from Nothing, to Wep (Shared/Open) to WPA... I'm not really sure what else i can do!
If anyone has an insight how to get this working, it would be much appreciated!
Thank you
figurt wrote:Hi,I'm trying to get my N80 to work with my wireless network.
Thank you
have you added you N80 mac address to your router/modem, you may have mac filtering on and thats why you get the error..
Checked mac filtering, has always been switched off.
figurt wrote:I've tried changing the security settings from Nothing, to Wep (Shared/Open) to WPA... I'm not really sure what else i can do!
is this on the router or the phone or both? (they both need to be the same!)
i would turn off security on the router whilst you get it working then use 128bit wep with 10digit hex code to make it secure (well secure enough for the average home).
I have the same problem as figurt, but i�m trying to connect to my University wi-fi network, so I cant change anything in the router:redface:
I can connect to other wi-fi networks (home network, hotspots...) but I cant connect to my university..
Tried everything, but just cant do it..
I even changed the cyphers, but nothing.. Just "No gateway reply" :frown:
I have found I get this error when the phone loses connection, or has a bad signal to the router, try it right next to the WIFI router, the reception on this phone is not that good, I would put the phone on the floor, quite near to you router, get a WIFI conection and then shit on it🙄
hi Im new in this forum and i have the same problem last night when I tried to connect to internet and comes out an Error Gateway not found I have seen all the settings on my cellphone and everything seems to be normal. What this could be? :con?:frown:
Thanks.
