ok i wont work ive tryed everything im connecting with infared (i know i should use bt) i guess im cheap :P but there must be a way i can get it to work it just wont connect help 😊
pc suite
Perhaps you may wanna update your ir or bt driver?
My 7650 connects fine if I uncheck/check the BT Ser port in mRouter, does this work with IR? IR? sooooooo old, check out BT tightwad.
Me thinks your not missing much anyway!
:roll:
anyone here using the nokia pc suite with win98 and msi BT dongle?
Me 😃
