VOIP wont use WiFi
0 replies · 1,870 views · Started 14 October 2006
I've configured my E60 VOIP setup to use my Sipgate voip account and connect over my home wifi (it is set as the default access point in the SIP settings)
With the SIM removed it all works fine, with the SIM in Voip fails to register. It doesn't even look like it tries to connect over WiFi or over 3G / GPRS.
It does prompt "create WLAN connection in offline mode" when I try to register without the SIM in)
NE1 any ideas?
